reverse binds
soapisclean
May 24, 2011
pittsburgh, Pennsylvania
when i go into reverse, and start moving my car binds kind of, its rather subtle. but i hear like a clicking noise almost and when i hear that noise the car stutters a little bit. this happens when im actually in reverse or when im just drifting backwards in neutral. the steering wheel also jerks a little. but everything works fine when moving forward. anyoen ever heard of this? ive checked everything on the suspension and it seems tight and fine. also recently my front suspension has become far more noisy when going of bumps and potholes. could this be an alignment problem. i have kyb agx shocks and eibach prokit springs.
Sounds like the haft shaft might be binding or you have a shaft bearing going out., I would vote the later.
i actually found the problem, turns out one of the caliper bolts fell out WTF and i assume when i would go into reverse and apply the brakes it would slide the caliper off the rotor and it would hit the inside of my rim.
