Return of the F*&ked up clutch
420a16g
309
Jan 4, 2005
Bristol, Virginia
well guys a couple monts ago i got my clutch replaced with the Centerforce DF. I got wore in like the instructions said and everything and everything was going good. So today im gettin of the interstate, push the clutch in to take the car out of gear and the clutch pedal sticks to the floor, then bounces back. So i really didnt think much of it, but im already on my way to my mechanics so i think ill just get him to check it when i get there. when im almost at the shop the clutch pedal losses all pressure, and i cant change any gears or even engage the clutch, so i take it out of gear and coast into the parking lot (lucky me).
my mechanic looks at it and says its either the a hole in the clutch line leaking fluid or the slave cylinder is gone. regardless it sucked ass. what was really funny is it happened right after i got my inspection sticker. but im assuming it will be fixed tomm. i dont know if this has ever happened to any of you guys but just wanted to vent to some DSMers..
yep,
just hade to fix mine
it was the master clinder for the cluch
and I replace the slave clinder sence I was there
Well i got lucky, slave cylinder was fine, there was a leak in the SS clutch line, right where it screws on to the cylinder or whatever. anyways got that replaced and a fresh oil change.
new clutch line - $10
fresh oil change - 25
labor - 45
knowing your DSM owns your life - PRICELESS :thumb:
