96gstdsm
- 808
- 2
- Aug 7, 2006
monroe,
New York
OK well I had asked this in my other thread pertaining to my 6 bolt swap and lots of blue smoke etc.
I got my oil changed today after about 100 miles on my break in for my new block and turbo. When I got home I noticed my exhaust was smoking alot. Blue smoke. I then popped the hood and I could see oil bubbling out between the exhaust manifold and the head. I wiped it down and checked again and it was definitely coming from there. Could see it oozing out from every bolt hole. Mostly the far most left and right sides of the exhaust manifold though. I jacked the car up and when running you could see oil just dripping off the car and to the ground. Now I didn't get so far as to really check to see if there were other leaks underneath the car, but looked as if there might be.
I later checked the oil level and it seemed to be very high. I replaced my dip stick some time back since it broke, and bought an oem replacement one. So I am assuming it measures the same.
On the receipt from the oil change it showed that they put in 4.7 quarts which is normal for an oil and filter change.
I checked the oil level and it is way over the second notch. It is about the same amount over the second notch as the second notch is from the first notch.
Could this be effecting my car negatively? Could this cause oil to get there and work it's way out the exhaust manifold? Would this cause the car to blow smoke out the exhaust pipe?
