Restet the computer and the car runs like ass now ??
psi on u
92
Feb 15, 2004
galloway, Ohio
Ah i got my car back from getting some stuff done to it and it was running just fine infact better than fine, i had just put on my intake pipe prior to the work getting done. I undid the negitive side to the battery so i could mount my boost gauge switch and i put it back on and now the boost isent comeing up nearly as quick and it seems that the engine is working harder to get it to rev ??? so i checked for vacume leaks i put new plugs and wires in it and it still is doin it i mean WTF is goin on. Any advice or suggestions is greatly appriciated thanks :cry: :cry: :cry: :cry:
Make sure all your clamps are on good, I bet you have a leak. Did you actually do a pressurized test?
the boost gauge dosent show any vac loss at all the, also the car like sputters kinda at idle
I was having alot of trouble with my car after the ecu was reset on a few occasions. The thing that worked for me was allowing the car to sit at idle for a good while: 10+ mins, without touching it. After that my problems were solved on all occasions.
i did and it just still kinda putts in the exhaust but the revs will not really move nor will the boost gauge , Im thinking that it might be the injectors or possible the cat clogged up ?????
