[RESOLVED] won't rev over 2000
bigdukk2
52
Oct 23, 2007
Manistique, Michigan
so i'm gettin my 99 gsx back on the road after sittin for 8 months in the garage.. been waitin on a tranny from jacks transmission.. with evo gears :D :hellyeah:, so i got it all in.. and everything is together... and i start it up.. .voila.. it starts no problem.. no issue... and then i let it warm up...
its warm.. bout 100 degrees... and then i roll on the throttle... no go... i roll on it again and hold it to the floor... car slowly edges to 2k rpm and then holds there... doesn't sound like its runnin crappy at all.. i logged a little bit of it.. here it is... what ya think guys... maf issues?.. or somethin else?
Recorded Data
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 980
CALC LOAD % 18.8
MAF FLOW GR/SE 4.42
COOLANT F 107
IAT F 64
IGN ADVANCE DE 9.0
ST FTRM1 % 2.3
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.800
ST FTRM11 % 0.7
O2S12 V 0.000
ST FTRM12 % 0.7
OBD2 STAT CA
Frame -5 Time -18.3
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 976
CALC LOAD % 19.6
MAF FLOW GR/SE 4.43
COOLANT F 107
IAT F 64
IGN ADVANCE DE 11.0
ST FTRM1 % 0.0
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.380
ST FTRM11 % 2.3
O2S12 V 0.000
ST FTRM12 % 2.3
OBD2 STAT CA
Frame -4 Time -14.7
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 1019
CALC LOAD % 18.4
MAF FLOW GR/SE 4.38
COOLANT F 109
IAT F 64
IGN ADVANCE DE 8.0
ST FTRM1 % 0.8
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.500
ST FTRM11 % -1.0
O2S12 V 0.000
ST FTRM12 % 0.8
OBD2 STAT CA
Frame -3 Time -11.0
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 964
CALC LOAD % 19.2
MAF FLOW GR/SE 4.31
COOLANT F 109
IAT F 64
IGN ADVANCE DE 9.0
ST FTRM1 % 2.3
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.720
ST FTRM11 % 0.7
O2S12 V 0.000
ST FTRM12 % 0.0
OBD2 STAT CA
Frame -2 Time -7.4
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 941
CALC LOAD % 19.6
MAF FLOW GR/SE 4.25
COOLANT F 111
IAT F 64
IGN ADVANCE DE 11.0
ST FTRM1 % 0.7
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.480
ST FTRM11 % 1.5
O2S12 V 0.000
ST FTRM12 % 2.3
OBD2 STAT CA
Frame -1 Time -3.6
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 988
CALC LOAD % 18.8
MAF FLOW GR/SE 4.37
COOLANT F 111
IAT F 64
IGN ADVANCE DE 11.0
ST FTRM1 % 0.0
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.580
ST FTRM11 % -2.2
O2S12 V 0.000
ST FTRM12 % -1.0
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 964
CALC LOAD % 19.6
MAF FLOW GR/SE 4.37
COOLANT F 113
IAT F 64
IGN ADVANCE DE 9.0
ST FTRM1 % 3.1
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.860
ST FTRM11 % 1.5
O2S12 V 0.000
ST FTRM12 % 0.7
OBD2 STAT CA
Frame 1 Time 3.8
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1496
CALC LOAD % 18.4
MAF FLOW GR/SE 6.83
COOLANT F 113
IAT F 64
IGN ADVANCE DE 19.0
ST FTRM1 % 2.3
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 1.000
ST FTRM11 % 0.7
O2S12 V 0.000
ST FTRM12 % 0.0
OBD2 STAT CA
Frame 2 Time 7.4
MIL STATUS OFF
ABSLT TPS % 65.0
ENG SPEED RPM 1632
CALC LOAD % 18.4
MAF FLOW GR/SE 8.40
COOLANT F 113
IAT F 64
IGN ADVANCE DE 21.0
ST FTRM1 % 0.0
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.820
ST FTRM11 % -1.0
O2S12 V 0.000
ST FTRM12 % -2.2
OBD2 STAT CA
Frame 3 Time 11.1
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 1093
CALC LOAD % 18.0
MAF FLOW GR/SE 5.91
COOLANT F 113
IAT F 64
IGN ADVANCE DE 20.0
ST FTRM1 % 0.0
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % 0.0
O2S12 V 0.000
ST FTRM12 % 0.0
OBD2 STAT CA
Frame 4 Time 14.8
MIL STATUS OFF
ABSLT TPS % 95.6
ENG SPEED RPM 2113
CALC LOAD % 15.6
MAF FLOW GR/SE 8.46
COOLANT F 114
IAT F 64
IGN ADVANCE DE 22.0
ST FTRM1 % -4.9
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.200
ST FTRM11 % -3.4
O2S12 V 0.000
ST FTRM12 % -2.2
OBD2 STAT CA
Frame 5 Time 18.4
MIL STATUS OFF
ABSLT TPS % 95.6
ENG SPEED RPM 2097
CALC LOAD % 15.6
MAF FLOW GR/SE 8.28
COOLANT F 114
IAT F 64
IGN ADVANCE DE 25.0
ST FTRM1 % -2.2
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.960
ST FTRM11 % -4.6
O2S12 V 0.000
ST FTRM12 % -4.6
OBD2 STAT CA
Frame 6 Time 22.1
MIL STATUS OFF
ABSLT TPS % 0.7
ENG SPEED RPM 1101
CALC LOAD % 17.6
MAF FLOW GR/SE 4.63
COOLANT F 114
IAT F 64
IGN ADVANCE DE 13.0
ST FTRM1 % -6.3
LT FTRM1 % 0.0
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.240
ST FTRM11 % -5.1
O2S12 V 0.000
ST FTRM12 % -4.9
OBD2 STAT CA
Frame 7 Time 25.7
please look at the maf % and the tps %.. i'm not real sure what a normal maf reading is.. but the maf was never touched... i actually borrowed it for my 95 talon... ran great... i just wanted my gsx back on the road...
i can' get it figured out... how about a way to test the O2 sensor?... or a list of what would cause this?... i tested the MAF .. its fine... :tease:
figured it all out... so get this... i forgot to take the waxing sponge i plug my turbo with out of the turbo inlet.... it was deep in the 'ol E316g, so i pressure tested the whole system anyways trying to find out what had caused the problem(before i found the plug) and it had like 8 boost leaks... massive leaks on my tb, so i just pulled er out and stuck the ol 1gt on her... she likes it alot ... crisp.. and quick response now...
