[RESOLVED] What part is this exactly... (clutch fcu, accumulator)
98DropTop
577
May 11, 2005
Thunder Bay, ON, Canada
Can you tell me what this is called... I think it is the part for the clutch where I was reading it helps with the clutch response if it is removed or something..... Is it important? any info would be helpful, thanks.
Thats the clutch fluid reservoir, it goes from your factory hard line to the slave cylinder. Most people i know including myself replace these with SS braided lines.
Its the accumulator for the clutch. Taken off pass side right? If you run a stainless line from master to slave you'll get better response.
ok good, thats why its in my hand... LOL... I already have a ss line in place of it, I just had some clutch problems today and cant get my car into gear so I wanted to double check with you guys to see if I accidentally made a boo boo taking it out... haha
Removing it will cause no harm.. Just bleed your clutch a few times again to see if that fixes it.
