[RESOLVED] What is malfunctioning Eprom, Chip, or Something Else?
Jdiddy2k4
271
Jan 19, 2004
San Antonio, Texas
Little background before I state the problem. I have a 98 gsx and I put the wideband in my 2nd o2 spot so naturally the ecu throws the heater circuit bank 2 code every now and then, but I just clear the code and it doesn't come back until the car is shut off and restarted sometimes.
Fast forward to now. I have a 95 eprom ecu with a keydiver chip in it. The first few days the car was running exactly the same the ecu would throw the o2 code and I would clear it and be done. But NOW when the code is cleared when it comes on, but now while I am driving, the ecu throws the code again and when the code comes up the car bucks also. Sometimes the CEL will go off before I can even hook the logger up to clear it, and if I have time to pull the code, it is the 02 code again. And it will just randomly come on. What would be causing this problem?
I had the same code on my car it also is a 98 eclipse gsx whta it could be is a ground wire that is connected to the frame of the car and your downpipe and catback exhaust cause when I bought my exhaust system that code came up because I broke the ground wire when I removed the stock catback so checked the ground wires.
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
