[RESOLVED] Turbo oil feed crush washers
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
So I searched and everything is for oil return.
My 16g oil feed banjo bolt is leaking. I need to know what size it is so I can get two crush washers. Its something I can drive on but I really dont want to. It is also causing my car to leave dribble spots when the car sits.
Extremepsi has crush washers but I need to know what size before I buy them
Yeah sorry, I wasn't clear on that. Its leaking on the turbo not the head. Also am I suppose to use 2? one for top and bottom?
Yes. In spect the turbo section for any large nicks same for the bolt on the mating side. The crush washers are soft enough they should seal but make sure you have a clean flat surface before crushing them. Also they are "technically" a one time use part. So anytime you undo the line your supposed to replace them
-Kolby
Thanks Kolby!
Looks like I will head over to ace hardware performance tomorrow... Every other bolt is from there why not the crush washers...
