[RESOLVED] Td05 20g turbine nut torque spec?
I torque every turbine nut to 100 inch/lbs; approximately 1/4 turn after the nut has fully seated against the compressor wheel. Never had one come loose, never had a turbine shaft bend or snap.
Use a drop or two of red loctite on the threads.
