[RESOLVED] slave cylinder boot leak
DearDoger
123
Jan 26, 2008
Battle Ground, Washington
the rubber boot on the slave fills with fliud swells up then springs a leak dumping all the pressure from the pedal leaving me with a clutch pedal stuck to the floor. Is the slave shot or wtf why is it doin this.
yea the scrapper seal is shot. time to replace and like said above I'd replace both the slave and master cylinder
If you dont want to buy new master and slave cylinders, they do sell a rebuild kit. I rebuilt both of mine about 1000 miles ago and they are working fine so far.
I went this route and I was only able to find the repair kit for the slave cylinder at Advance Auto, the master cylinder I had to buy new because nobody here locally sold the repair kit for it..not even SATAN....:notgood:
Yea just get a new one and a steel braided clutch line if you dont have one already, before it goes and leaves you stranded on the side of the road with your clutch pedal stuck to the floor.
