[RESOLVED] Remove cam, And Reinstalled with 3g lifters
4Motion4g63
257
Feb 27, 2005
Lawton, Oklahoma
I cannot find any instructions on how to Properly install cams.......
All the links ON VFAQ are not working.... and it only shows how to install lifters with cams IN the head, I have removed my cams to install my lifters due to some tight clearances and just dont like working like that......
I also had to take off my timing belt to set the timing again so the front of the motor is also apart.
I tryed to keep things all lined up like i took it out, but just dont want to take any chances, I almost dropped the cam and could have mixed up the orientation that i removed it from the car....
How tight do i torque down the bolts too! seam to be easy to make really tight but dont want to break the threads or overtighten them....
May sound stupid but when the crank pulley lines up with the timing mark is that TDC?
I replaced cams in with the timing marks lined up and the Dowl pins at the top....
My cam sprockets are in the same way these are notice the dowl pins just above the bolt holding the cam sprockets on..... Is this correct...
