[RESOLVED] need to know what this line is
slim2005
119
Dec 8, 2007
Dodge City, Kansas
hey you all i finallygot the motor dropped in but don't know what this line with the flared end is for. it's located underneath the fuse box...
:talon:what is the part that what i need to know i have all sorts of parts and lines.. just need some help
Its part of your clutch line. Follow your clutch line from your clutch master cyclinder and it should lead to that line. The other end that is not connected is suspossed to go to the tranny. The part that connects to that line should a cyclinder looking thing hooked to it with a metal line that will hook up to your clutch slave cyclinder
Its the hard clutch line out of the master cylinder. It connects to the rubber hose that then connects to the Clutch accumulator.
Yes clutch line. Think back when you took it off, you would have had to remove the clip that locks the rubber line into the bracket and the flared line goes to it. Go to your tranny where the clutch fork is and lock at the slave cylinder and follow it back
got it back in...i never pulled the motor or trans. it was out when i bought the car.... Thanks you all for all the elp i'm sure i'll need more before this is over.. but yeah it was clutch line.
