[RESOLVED] Need help with 2 connectors, under dash, frame harness pics inside need he
silver bullit
2,312
9
Jan 27, 2006
martinsburg, West Virginia
Need help with 2 connectors, under dash, frame harness pics inside need help ASAP
First 2 pic is looking at the car like this looking at the driver side door looking into the car from the outside through front window
the last 2 is from the inside like you are siting in the seat.
The dash has to be pulled to see this connector:
I is part of the frame harness that is bolted to the frame rail that supports the steering column, it sits right next o the speed cable. Almost right behind the controls for the heater etc.
I have looked for almost an hour and i cant figure where it goes.
I just had my instrument cluster out so I might know. if you are looking directly at your dash the speedo connector is off to the right and all the way to the left there are two connectors that connect to the instrument cluster finish panel for the dimmer and i forget what the other one is for but its right above the dimmer.
Thanks for the help BUT THE DASH HAS TO BE OUT OF THE CAR to see this one.
It's hard to say since there isn't much to reference but my best guess after studying the FSM configuration diagrams and looking at my parts car is that those are C-09 (Blower Switch) and C-10 (AC switch).
Wow...wow...wow.
I need to go get some sleep staying up for days=not good. I fell so dumb now. I thought that was part of the dash.
Thanks.
