[RESOLVED] NEED HELP FAST!!Sputtering a low rpm's at low throttle
ibspoolin2
103
Jul 9, 2008
Gilbertsville, Pennsylvania
Hey guy i just bought a 91 laser rs with the 2.0 dohc Non Turbo. ok its pretty much stoch all it has is a obx header obx cat and a short shifter. ok for the problem when your at low rpm's ( under 2000) when pulling out it has like a fluttering sound and theres no power. but when you get past 2 grand it like pulls its self out of it and runs normal. also when your driving in a high gear at low rpm's and give it alot of gas it does it.? i have no clue anymore. Please i need help:cry:
ok how do i clean the MAF sensor
Go to you local auto parts store. Buy a can of MAF sensor cleaner in a spray can.
Remove the MAF from the intake pipe and spray the SHÏT out of it until it sparkles... There's a little sensor inside so make sure you get that guy too.
Good luck,
Tom
hey guys i found the problem and fixed it. ok here it was the person that owned it before me gapped the plugs to .60 LOL so on the #3 cylinder sparck plug wire it arched through the wire and was groundeing out to the head.
