eclipse gsx sputtering at low rpm's
ctsellersjr
Nov 12, 2012
florence, South Carolina
I've searched and I've searched and i can not find the problem. My built Gsx sputters at low rpm 3100 and lower. It hesitates on take off and sputters until i go pass 3100. Any help would be appreciated. Also its a 6 bolt swap
MODS:
act streetlite flywheel stage 4 clutch
je piston 8.5:1 with rings .020 over
cometic head gasket
arp studs
holset hx35 turbo
greddy exhaust
shepperds stage 1 tranny
acl main bearing
acl rod bearing
1050cc injectors fic
tail bov and wg
gm maf
eagle h beam rods
eagle forged 4340 chromoly crankshaft
balance shaft eliminator kit
topline lifters
extreme psi oil cooler kit
MODS:
cometic head gasket
arp studs
holset hx35 turbo
greddy exhaust
acl main bearing
acl rod bearing
tail bov and wg
gm maf
eagle h beam rods
topline lifters
You got a tune done to your car? What are your spark plug gaps to and what type brand are they?
I drive a 95 GS, I have a similar problem with the car but its a N/A 420A. I had some problems with the car last week and while my girlfriends dad and I were taking care of it he questioned me while it was running if the car just stalls out while sitting at a red light and yes it does. I have replaced my fuel pump, fuel filter, spark plugs, and plug wires. He took a deeper look at it and says I may have an injector problem(which we have not tested yet to make sure of). If i try to take off it just spits and sputters till I reach about 3000rpms. Check there along with the fuel pump might have a cylinder dropping out at low rpms(I do, but it will catch up at higher rpms).
