[RESOLVED] missing plug...where can i find it?
smokeyjpn221
115
Oct 27, 2008
salem, Virginia
when i bought my eclipse it didn't come with the plug on the passenger's side of the the engine that goes in the hole on the valve head and cover:banghead:. is there anywhere i can get this other than i dealership? i need one ASAP. thanks :thumb:
Do you mean the half-circle piece that fits under the bottom edge of the valve cover? If so, then you can get those at the dealer. They come as part of the VC gasket kit, so you might as well replace the whole kit at the same time while you have everything apart.
Unless he means the CAS.
If it's the half-moon seal, go to Autozone or Carquest and buy a valve cover gasket set and replace the whole thing. It's like $30. Open the box before paying. It should have 6 pieces. The half-moon seal, four circular plug well gaskets, and one big gasket that goes around the perimeter of the whole shebang. Search about how to replace the gasket, or you may very well break the valve cover when tightening the bolts. New VCs are kind of expensive.
