[RESOLVED] Loppy Idle, Really Rich. Any ideas?
knochgoon24
DSM Wiseman
6,135
98
Jan 29, 2008
Troy, Michigan
So, I just finished a whole bunch of work on my car. I started it up, and after finally adjusting the BISS, I got it to idle around 800 rpm. Now, I didn't touch that screw at all while I was working, and it idled around 750rpm before.
Secondly, the car is running pig rich. It's really really bad. Every once in a while it backfires. I hooked up an OBD2 logger to it to read the o2 voltages. Both are less than .24v for the minute I ran it. I can smell the unburnt fuel in the exhaust.
When I pulled up the short term fuel trim. It's adding 17% more fuel at idle. The long term is at 12.5% right now.
So far, I've done boost leak test. It's good. Any other suggestions as to what might be wrong?
Here's 2 videos.
This is the engine idling. I did a BSE, but this still seems really rough.
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/cqWsvvxNcLc"> </param> <embed src="http://www.youtube.com/v/cqWsvvxNcLc" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
This is the exhaust. It's full 3" with a cat.
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/iP5eQUFS6XE"> </param> <embed src="http://www.youtube.com/v/iP5eQUFS6XE" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Pull the vacuum line off the fpr, & check that there`s no fuel inside the vacuum line . . . if there is, the engine is sucking raw fuel in & running pig rich, & the fpr. is leaking & needs to be replaced . . . :talon:
