[RESOLVED] Explanation of how a BOOST leak can cause FUEL cut? Please.
SnowBird
527
Jul 9, 2006
Cleveland, Ohio/Tampa, Florida
I keep hitting fuel cut out of nowhere around 14lbs, when I usually can run 15lbs all day long all day strong with no problems. I havent checked it yet, but I heard a boost leak can cause this "cut" and I didnt see how if the air leaks/enters after the MAS. I just dont understand how it happens.
Im a true NEWB still, I still get off on stage 0 mods and stock fuel trims :D
A boost leak causes the turbo to work harder to maintain the same intake tract pressure. While working harder it draws in more air thru the MAS and the ECU sees this excess air and cuts fuel. You don't see more boost at your gauge because it is leaking out somewhere, but your airflow is higher nonetheless.
Just go over all of your piping. If you can do a boost leak test that would be great an spraying soapy water over your couplers helps to see air bubbles. If its not any of the connections or piping do not forget to check the fuel injector seals an throttle body gaskets. Also could be a vacuum line came off.
