[RESOLVED] engine bay pic, what is this?
WILOWNU
132
Mar 9, 2006
Wheelersburg, Ohio
the car is a 95 talon with a full 6 bolt swap.
what is this plug coming off of my throttle body?
Where does the wire for this go?
Can I run a wire from it straight to the ECU?
If you cant tell by the picture I have taken, say something and I will take one from a different angle.
That's the throttle stop switch or idle set screw, etc, etc. It tells your ECU when the throttle is completely shut and is absent on 2Gs so I'm not sure how you'd hook it up to your ECU.
since I am using a 1g throttle body do I have to hook it up? or can I just leave it as is?
