[RESOLVED] Does anyone sell an entire T-Belt kit??
eclipsed95
1,288
Nov 7, 2002
Romney, West Virginia
I searched and read a bunch of similar threads about this, but here's the question. Does anyone sell a timing belt kit for a 2G that includes everything that can/should be changed. I bought a set of BC 272's and definitely am doing t-belt, balance shaft belt, and cam seals. I thought it'd be a good idea to do the tensioners, pulleys, and accessory belts too. When you put them all together separately, it gets pretty expensive especially for OEM stuff.
Any ideas? Any vendors out there with reasonable prices for all in a package deal?
Thanks in advance.
4G63 4G63T 2.0 DOHC Timing Belts & Bearings KIT Mitsubishi and Hyundai
They also have other parts you might need while you're doing the timing belt.
4G63T Mitsubishi 2.0 DOHC Turbo Engine Rebuild Parts
That's where I bought my water pump from, I think it costed me $30...they have great prices.
Actually looking at them seriously.
Timing Belt GATES T167 -Gates $46.95 $46.95
Timing Belt Tensioner Bearing Mitsubishi and Hyundai T60091 -PCI $14.90 $14.90
Balance Shaft Belt Tensioner Bearing Mitsubishi and Hyundai T60105 -PCI $20.05 $20.05
Timing Belt Idler Bearing Mitsubishi and Hyundai T65274 -PCI $19.00 $19.00
Mitsubishi New Water Pump 95 - 99 28-7148 -ITM $29.00 $29.00
Accessory Belt Package 4G63 Acc. Belts -Gates $33.90 $33.90
$176.96 shipped, not bad. Then I'd only need the cam seals. What do you think?
I think it's a great deal, it was the best I could find when I ordered my water and oil pump.
So here's what I ordered. Can you guys see anything I missed? Should I have ordered an oil pump while I was at it? I haven't really seen that everyone does that when they do timing. Or would I be good with a new gasket?
(2) Mitsubishi Front Cam Seal
Mitsubishi 2.0 Timing Belt
Balance Shaft Eliminator Kit
Timing belt change: A complete list of 60k timing belt service would include all these:
- Timing belt
- Balance shaft belt
- Timing Tensioner
- Water pump
- Timing belt tensioner pulley
- Balance shaft tensioner pulley
- Idler pulley
- Crank seal
- Oil pump seal
- Balance shaft seal
- 2 Cam seals
- Harmonic balancer
- All other belts
http://www.dsmtuners.com/forums/frequently-answered-dsm-questions/239375-maintenance-schedule.html
