southrneclipser
- 214
- 2
- Jul 30, 2009
horn lake,
Mississippi
OK my 95 eclipse 420a is overheating and idk what to do with it anymore. i pulled out the engine and tranny to do some maintainance. Its got:
- new water pump
-new rad
-stock fans (work fine)
-70/30 coolant mix
-new thermostat
-16 psi rad cap
It ran fine for about a week and now the water temp has jumped up to about 125-135 degrees. This was driving with hood off by the way. It usually stays around 95 degrees. It also stopped putting out heat from the vents. When its off steam is escaping from the overflow hose so it wont hold pressure. Could there be a bubble in the heater core thats not letting coolant circulate through it? If so wy would it be releasing pressure from the overflow hose. This is my DD to school so any help is greatly appreciated.
by the way one of the hoses is disconnected from the a/c compressore. i didn't think that mattered but i figured i'd let you all know.
- new water pump
-new rad
-70/30 coolant mix
-new thermostat
-16 psi rad cap
