[RESOLVED] can't get push button start to work
Please someone help me! I have tried hooking it up all different ways. It seems like the 87 pole on the relay, which is yellow is not doing anything. I did power tests and it seems like its just a ground which would make sense for the button.
86 pole I wired directly to a ground so that should not be a problem (black wire)
pole 30 I ran to the black/white wire under the dash at the harness for the starter
pole 85 went to the black/red wire for 12v power and also spliced into that for direct power to the actuall button
Pole 87A which is red he says is not used...and as far as I can tell this is not a ground or a power according to my tester.
So I don't know what else to try...someone help please and thank you
Ok, I have even made a little diagram on how I installed it...god I hope someone figures this out, I am an electical retard.
That "diagram" is a mess ^
This is how you need to do it.
Also, Im not seeing the point in really doing this. You realize youre still going to have to put your key in and turn it to ON (to give power fuel pump and ignition) THEN you can hit the start switch right?
yes that is nice to know, good knowladge to have! But it wasn't that, I figured out that the actuall button was not transfering power from the power wire to the starter wire. So I hooked up the Engine Start button just to power and ground for the light to come one, then made it so that when I push that button it triggers another button under the dash that actually transfers power and hooked up the starter wire and power wire to that button. WORKS NOW!! thanks for the information though I always kinda wondered that.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
