[RESOLVED] can i up my boost?
iammikesevvy
30
Nov 15, 2006
howell, New Jersey
ok guys im new to dsm...but i bought a 95 gsx and it has a evo III 16g turbo running at 11psi..... i just got exhaust and fmic and i have dsmlink on the way... what can i turn my boost up to safely? Thanks
LIek the first reply asked. What do you have for fuel support? Bigger pump, is it re-wired, bigger injectors, AFPR, anything? IF not wait for DSMlink
yea everything else is stock...thats why im not sure if i should turn my boost up or not...but after i get dsmlink what should i do?
In my oppinion no. Rewire the fuel pump. Once you get DSMLink measure your IDC and knock.
There may be some fiddle room. Best of luck. Your limited by your fuel or lack there of.
I run 9.5 psi on my big 16g with stock injectors. I know because of my Wide band that at 9.5 psi I am rich 9:1 ... which is still stock. Stock ECU runs rich. I would research tuning and using DSMLink alot before upping the boost. Get it running great at 11 psi. then work on increasing the boost a little at a time.
And by no means am I good tuner as I really haven't adjusted my DSMLink.
Flat answer, you can up the boost to 13-14 psi. That's the most common answer you'll read. Just wait till you get your link and fuel support before you up it up. Shit I'd be happy with a gsx.
You can only adjust the timing by a little, so i wouldn't worry too much about it, but i would get more fule into that engine then a nice tunning. Good luck.
