Resistor Pack
blueman803
216
Nov 3, 2003
chapin, South Carolina
Hey, I hooked the resistor pack up to the cut injector wire like in the diagram, but it causes the idle of my car to shoot straight up to 3000 and stay there, what could be causing this? If it is disconnected the car idles at 1200
sounds like you tapped the wire for the tps sensor,since the tps is just a variable resistor anyways.
resistor pack or box? mine does the smae thing, or did. are you using a safc or a fuel management system?
Sounds like you tapped the wrong wire somewhere.
Glad to hear you got it figured out and it wasn't anything expensive.
