how do i wire in the resistor pack???
jamesbombed007
Apr 13, 2005
Lethbridge,
me and my frends have searched everywhere... i need to know howto wire in the resistor pack onto my n/t 92 harnes. i'v already got the MAF and NOCK sensor wired in but need to know how to wire in the RESISTOR pack...
any help is greatly appreciated. p.s. i have a 92n/t and am almost done the 90 4g63-t swap. just need to no how to wire in my RESISTOR pack....
THANKYOU!!!
everything you need to know is in the nt to turbo swap that i think defiant put up,there is a detailed description on resistor pack.good luck
allright wiked! can somebody find that and post the link here??? i'v been looking with no luck....
THANKYOU! :D
ok........ so iv just spent 7more hour's on this section. i think i found wat i was looking for in mavisky's thread. so i havee a 92n/t and i swaped in a 90 4g63t....
yes i now no how impossible this swap is. but on the rout im taking for it... i no longer need the FPS or the wastegate solonoid....
i am adding a MBC and pod style boost guage....
as for the rest it is swapped and done. adding the 7th MAF and nock sensor as we speak.
still working on the IRP (injector resistor pack)... yes verrrrry confusing.
but... im still a little scetchy on the swapping of pin's 6 and 14... do i just make the wires (green and green with white stripe) on my n/t harness match the 90turbo harness? :confused: :confused:
i am using the 90 4g63t and ECU....
once again THANKYOU for any and all help!!!:D
That part was very hard for me to understand also. But just follow the DIAGRAM 100%. I had to just clip 3 additional wires and just tape them up. So that they did not connect to anything. It has been working great for me. The thing that was hard for me is that my wire colors matched the turbo car wire colors.
I know that I will take some pics one of these days so that everyone can see how my build went.
