JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
I'm replacing the head on the 6-bolt 4G63 in a customer's 1G Talon non-turbo with one from a '95 Talon TSi. The engine is getting a full rebuild as well- it has nearly 200k on it.
I'm already well aware that the heads are interchangeable; my question is would it be wise to swap the non-turbo cams into the turbo head to keep the non-turbo cam profile in the car, or should I leave the turbo cams in the head as an "upgrade"?
I believe the higher lift of the turbo cams would probably move the powerband to the upper end of the RPM scale, but I'm not sure if it would make the car undriveable or not (by taking away too much low-end torque.)
If anyone has done such a swap, feel free to chime in.
