Replacing clutch master cyl. in 2g
the idea of it is very easy. getting your hand into the tiny spot behind your shock piller is hard. I had to have my wife thread the bolts through there. I replaced my master and slave at the same time and the slave was much easier. the other hard part was disconecting the pressure line from the top of the masters body.
adjust ment was another thing that was very easy to do but took trial and error to get it JUST right.
set aside a day to do it. oh and before you start make sure you have a gasket for the master to the firewall.
