Clutch Master Cyl
Jip
Aug 18, 2005
SI, NY, New York
I know this is going to be a stupid question...
I am thinking of doing a manual swap in my 1990 Talon, but I can't for the life of me figure out where the clutch mast cyl would go...the brake booster is just soo close to the sidewall I cant see any space for the mast cyl. I don't have A/C so that fuse box over there is gone.
Does anyone have a pic?
Still doesn't make any sense to me. If the clutch mast cyl is directly under the clutch fluid reservoir then that puts the mast cyl to the left of the brake booster. Which means the clutch and brake pedles would be switched inside the car. That can't be right, what am I missing?
the pedal is not directly below the master. follow the pic's Defiant sent you and go from there it will all start to make sense when you get a manual pedal Assembly
Check this out:
http://www.dsmtuners.com/forums/showthread.php?t=196048
I have a lot more pictures and a write-up on rebuilding that pedal assembly that I haven't gotten around to posting yet, but from the pictures here you can see what is going on. The clutch pedal has a LONG axle that goes way to the right of the brake pedal, where it activates the clutch master cylinder.
