Replaced Broken MAS Now This?
Good to see you got it sorted out!:hellyeah:
Now get some slicks dammit and get back to the track!:p
Just installed some kumho spt's yesterday up front. They were picking up small rocks and pebbles as I rolled them across my driveway :hellyeah: . I'll be at the track this coming tuesday for street legals as long as it doesn't rain/not stupid hot outside.
Best of luck out there!
What do you plan to run for tire pressure?
They're at 30psi right now. I'll see how it goes from there and slowly lower it. I've read a lot of people say that street tires do weird things at lower pressures, but on my old tires I found 23psi to be the sweet spot. Only bad thing is if I go too low at the track I won't be able to air them back up, so I might try and get it figured out this weekend where I have access to my air compressor and a power outlet.
I've had pretty good luck with them ~18-20psi at the track in the skittle(2.06)
Car has a stock lsd right? I know not all of them do, but I don't know how to tell without driving one. With my rear suspension as jacked up and stiff as it is (super ghetto-unsafe home-made modification) I'm hoping for at least a 2.1, I got a high 2.3 with the old tires still blowing away 1st and 2nd on the low boost (15psi) setting.
It does have an LSD, 04-05 do, not 2003
Best of luck at the track, shouldn't be a problem hitting a decent 60' with the recent work you've put in:thumb:
