Removing Stock Amp Wiring?
iiNFAMOUSCHRiS
264
Sep 3, 2013
Kalamazoo, Michigan
I already pulled the stock amp from under the passenger seat, and replaced it with a new one to power my rockford fosgate speakers, but i'm going for a clean install(no wires are currently visible from the amp installation) but now i'm left with the wiring harness that went to the amp, as well as the proprietary audio cable that runs to it....just curious if I can just pull both of these wires completely out, without damaging anything?
well the question is more like can I just hack off the plug on the amp end(so it's just wires) and basically yank the whole thing through the dash where the stereo goes, without damaging anything.
I'm running all the speaker wires off the wiring harness, btw. And installing some new tweeters once I get paid, so i've got the highs too.
ahh, i thought the amp harness just ran from the stock radio to the amp....you wouldn't happen to know the color of the wire(s) would you? so I can cover those up when I pull it out. i'm only hacking the end off so it doesn't catch on anything when I pull it through the dash.
