Removing intake manifold
oldman
DSM Wiseman
9,789
196
Jun 21, 2003
Dayton, New Jersey
Hey guys, it's the first time I'm removing the IM and I have one question. How do you get to the bottom sencond bolt from the driver side without removing the AC compressor? Thanks.
Your answer was fine and I meant the thanks part. I was basically looking for confirmation that it can be done with the compressor in, just hope that my "manly arm" will fit in there. :)
Im pretty sure you don't have to remove the a/c.
On my other talon I got the 2 outside bolts on the bottom half, and all of the top bolts off no problem. I was going to try and get the other ones off but then I just pulled the head off with it on, then removed it, after the head was off.
On second thought, I bought my car from an insurance company and I am pretty sure it had a motor swap in it, and when the guy had the swap done he might have removed the a/c, I can't remember.
Try an extension, and a universal joint socket and see what happens.
Update: I know...been busy. :) I ended up pulling the DP, stick my arm up there with a 12mm and felt my way throught it. PITA
Thanks for the help.
