208DSM
- 48
- 0
- Aug 9, 2011
Emmett,
Idaho
so i have finally wasted too much time and money. i have a brand new 420A with 3,000 miles on it, i've had it back from the shop since April, it ran GREAT when i got it back, no stalls, no hesitation, nothing. then a month and a half later i put a header and full 3" Megan racing exhaust. about 10 days later i had my first stall. it just randomly died. car didnt overheat or anything. so about an hour later it started back up and i made it home from boise perfectly fine no problems. then it started doing it more and more. just randomly dies, when im driving at 25mph, 50mph, 70mph. so i replaced the fuel pump, fuel filter, crank sensor, cam sensor, cam sensor connector, coil pack, coil pack harness, upstream o2 sensor, IAC, cleaned the throttle body, fuel pressure check and everything was good, yet it broke down again. then 45mins later starts back up and drives good, when it runs it runs great. so ya, removing header and exhaust, good idea considering it never did it till i put the exhaust on?
i think my header is making something too hot and causing it to stall. IF YOU HAVE ANY OTHER IDEAS PLEASSEEEEEE REPLY TO THIS. I CAN USE ALL THE HELP I CAN GET.
