Removing hatch and gas lever?
There is a slit in the circle area where the cable goes in. You pull the cable a certain amount and you can slid the cable out when you line up the slit and the cable. It's similar to your throttle body cable. You'll figure it out once your messing with it. Super easy once you realize how it's done.
