removing exhaust housing
brandons95
74
Apr 23, 2006
deltona , Florida
i am going to tryto port out my turbo on my own but im not sure how to take the exhaust side off of the turbo any help will be great
cold housing + cartridge + hot housing. 3 parts. probably wouldn't go grinding to far if you don't even know how to take it apart. :coy:
i can get it apart just not sure if when i put it back together i have to line anything up ir is there only one way it can go, to take apart you just pull that circle clamp off correct
Yes remove the clamp. No it doesn't have to go back a certain way TO AN EXTENT!
It does have to be clocked right in order for your oil lines, and intake to line up right.
Use a paint pen and make a line across where both housings come off.
