Removing ECU
Your ECU is in the engine compartment. When you pop the hood look on the right hand side you'll see the fuse box, which has a black cover, with the order and size of the fuses written in white. Directly behind that, sitting horizontally is the ECU. There are only 4 or 5 10mm bolts that need to be removed.
Here is a pic of the location, thanks Baxsom :thumb:
