removing coil pack
unior
519
Oct 10, 2002
Lancaster, Pennsylvania
hi,
just wondering what the speical trick is to remove a stock 1g coil pack
i have already removed the 4 bolts that secure it and its loose but i can't seem to get it to completely clear the intake mani yet
its alittle hard to get out, just keep try wiggling it sooner or later it will finally make its way out, also try removing the bolts that secure the wire harness to the intake manifold(its kinda in the way keeping it from coming all the way out) try and move the wiring out of your way take some bolts out also remove anything else that isnt to vital and can easily be put back once u get it out and the new one back in.
yeah, someone else suggested just pulling the fuel rail - which is what i will probably end up doing
bigemrich said:
If you pull the fuel rail you will be golden.
--Kyle :talon:
yup -worked out fine - car is running good again
