Removing AFC and installing DSMLINK help!
missionx96x
136
Jan 30, 2006
Jackson, New Jersey
I just got DSMlink so i installed my eprom ecu and did the clutch rewire. Then i took out my SAFC by cutting all of the wires. I taped them all off at the tips, but now the car wotn stop. I think its because i cut the maf signal wire. Does anyone know which wires I have to reconnect? Can anyone help me here? please
thanks
thanks
When you put in your SAFC you had to put the SAFC in between the Airflow signal and the ECU. All the other wires you splice into. So you need to reconnect the airflow signal wire.
