Remove Exhaust housing from 16g
RBurroughs
173
May 31, 2004
Frederick, Maryland
I'm going to install an external WG setup off the o2 housing this weekend so I need to take the exhaust housing off for porting. Do i just remove the wastegate actuator and then the band-clamp in the middle?
Do I need to remove the turbo from the manifold?
Do I need to remove any oil/coolant lines?
Can i take the downpipe/o2 housing/ exhaust housing all of together?
Just:
-drop downpipe
-unbolt clamp in the middle, remove turbo bolts and remove the turbine housing and 02 housing all in one piece. Do what you gotta do and rebolt it back up and put the downpipe back on last.
Hey I have a spare turbo and after taking the band clamp off of it... I swear the two halfs are freakin gorilla glued together. Is there any kind of great way to get them apart? I've already hosed it down with pb blaster real good, but I swear that thing is stuck tight. If there's some kind of secret here, please let me know.
