Recirculate vent question....
91boost
221
Sep 17, 2004
Palm City, Florida
When I have my ac/vent on recirculate, you can still smell things outside(diesel trucks, etc). Is there something I can do to stop this from happening? I know its not supposed to be doing this.....
check your switch... it might not be changing over to recirculate... bad connection not telling the stuff to do what its supposed to do you know? Thats the best advice I can give you man... Unless the smells inside the car or leaking in from bad weatherstripping and the whatnot....
AdoreGSX said:
stop driving past diesel trucks, etc...DUHHHH
That was helpful. :rolleyes:
Pull the panel off and check the connections and what not.
Defiant said:
The push/pull cable may be improperly adjusted, or the foam gasketing around the door may be gone.
I was thinking either one of your 2 suggestions could be the culprit. When I switch it from outside air to recirculate, I can hear it change over- and you can tell the difference. It just isnt 100% recirculating....
I'll look for this in the manual tonight, to try to find a location of the problem and/or fix.
Thanks! :)
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
