nightspeed87
- 1,761
- 12
- May 2, 2006
Tampa,
Florida
( Its a little long but bear with me here. )
Ok to try to make a long story short, I rebuilt a 6bolt engine to drop in my car.
The engine had about everything replaced on it except the crank shaft ( got new bearings though) And the balance shafts were removed..
We dropped the engine in the car last weekend... Unfortunantly while we were still working on it and the hood was off it started suddenly pouring down rain, and the sparkplugs werent in the holes yet, but we quickly tarped it and threw the hood on top.
I know that water did get in there though.
The next day after everything was connected, we manually check it, and my engine builder
said he had the timing dead on. He tried to blow out some of the water out the engine with the compression stroke and the plugs not in the holes I believe.
Put oil, tried to crank, didnt crank, felt like starting an engine with spark plug wires in wrong locations. I took off the cas and turned it 180 degrees ( the only other way it can go ) This time it cranked, but cranked rough and sounded funny.
We turned it off like 3 seconds later, drained oil and the oil was milky and grayish.
( From the rain obviously since theres no way I have a blown head gasket on that new engine ) Drained, refilled, Cranked again. Let it run for like 5 more seconds ( still sounding funny ) turned off again. Drained oil, this time the oil looked regular, just had small shavings hear and there ( the size of sand particles and there wasnt many, they were break in shavings obviously ) As far as the engine sounding funny, there wasnt anything internally colliding because we manually cranked it over two or three times before starting it. But the engines funny sounds were coming from the head area. none the less, and it was running rough, we are concluding two things...
The funny sound possibly was because we didnt run it long enough to allow oil to circulate up into the head ( new head/ oil pump/ everything else.. ) Had the oil cap off when we started it and I didnt see any oil up there, yet we did lubricate all the parts while building engine. ( cant remember what we used. ) Maybe I shouldve ran it longer to see if noise went away as oil rose... Unfortunantly forgot to hook up oil sending unit so we couldnt see where the pressure was at. We dropped the oil pan after the 2nd crank and the oil looked normal still and didnt see anything abnormal.
Then we was considering the timing being slightly off causing it to run rough... The timing belt felt a little looser than it shouldve been,( we did replace tensioner though? ) but not loose enough were I thought itd pop off or anything... Not sure... Any ideas?
( This probably wont matter but, it has 2g pistons in it... And dont ask me why, long story; but it has n/t 4g63 camshafts in it )
) Anyways they were knicked deep, I could still run them so whatever. But the weird thing was is that only the intake side knicked and not the exhaust side... Why is that? Were taking the head back to the machine shop again and I purchased some turbo dc cams from a friend for 20 bucks ( There suppose to be the mix of the best turbo yr intake/ exhaust cams since the duration was improved in the later yr turbo 1gs ) Anyways the head had a 1yr warrenty and since it was already missing cam seals were speculating on the entire head build and will make them replace/ rebuild the head free of charge hopefully and install the turbo cams ( to take using n/t cams being a problem out of the equation. ) Were expecting them to find bent up intake valves on at least three of them.
