Rebuilt engine smoking oil
Frickadella
48
3
Jul 21, 2011
Saratoga, California
Well I'm baffled and tired...
Car is burning oil noticeably, though not ridiculous clouds, I don't think it'll smog like this. It's particularly visible on stationary revving. I don't notice smoke while I'm driving too much, except at low speed doing tight turns or pulling into drive. It usually doesn't smoke until warmed up, but I isolated PCV from intake today and it smoked cold too. Rebuilt engine top and bottom, I did the bottom assembly. It wasn't smoking before rebuild. It was a cracked head leaking coolant. Bought replacement cyl. head from distant shop. Had local shop look at it and they replaced 1 bent valve, 1 valve guide and the seals.
Compression Test : 185, 190, 185, 185 (warm, WOT, all plugs removed)
Vacuum Test : Steady at 16" at idle, but rises as rpms rise (not good :-( ). Drops to 2 psi, returns to 20" and slowly returns to 16 on throttle snap.
No leak down yet - I'd probably have to tow to a shop for that. Or buy a compressor and tester.
Absolutely no play in compressor shaft of stock t25 turbo. A finger wipe of oil in lower IC pipe. Oil pressure is not excessive.
Spark plugs were a fine even grey color.
VC breather was puffing air when I yanked line off and had PCV venting to air thru a filter. Still smoking.
The one thought I dread is I maybe installed a no. 2 ring upside down (there were no pips). Top ring was marked, but 2nd wasn't and I honestly can't remember any bevel or such. It was just a builders kit from Rock Auto if anyone has installed their rings.
As I see it, it's either TURBO PISTON RING SEAL or a PISTON RING issue, but who knows at this point.
Any suggestions, tests to do, etc. would be appreciated. Any way of positively identifying turbo as culprit before I tear head off pull out pistons? I have no idea about how to isolate turbo from running engine if even possible.
Car runs great btw, just smoking too much.
Thanks!
I had the same problem. If i would let the car sit for even 2 mins, and just touched the gas, I would be pulling a james bond smoke screen behind me and was quite annoying (especially in drive thru)!
Well I did a BLT and found that I had a leak at my injector seals and my bov. i swapped the bov out and ordered new seals. After the bov was swapped and waiting for the injector seals to come in, the car did not nearly smoke as bad as it did before. After I replaced my injector seals and fixed ALL my boost leaks, the car doesn't smoke anymore.
Boost leaks will make you smoke a little so try doing a BLT and see what you find.
Interesting. Turbos are my weak spot, so I didn't consider that a worthwhile test. Injector seals are new, but I'll check seating and do the test.
Thanks.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
