ShadeTreeDSM
- 269
- 0
- Sep 16, 2005
Fort Lauderdale,
Florida
got a 1993 awd 5-spd transmission i just rebuilt. new syncro sets & shift forks. running redline MT-90 for fluid mixed with 0.3qts of heavy shockproof. also installed new shifter cables, clutch master cylinder (adjusted properly too), slave cylinder (no air in line, all bled out), new clutch shift fork & pivot ball, Mitsu throw out bearing & sbr 4000 clutch.
when i shift into every gear it will shift smooth. but when i down shift at about 15mph into 2nd it will grind.
. this trans doesnt even have 200 miles on it and its grinding.
found this out today though, if im in 3rd and i want to downshift into 2nd, i put it in neutral and rev the engine to match vehicle speed, then when i go into 2nd its smooth as any other gear.
what's causing this
. this trans doesnt even have 200 miles on it and its grinding.found this out today though, if im in 3rd and i want to downshift into 2nd, i put it in neutral and rev the engine to match vehicle speed, then when i go into 2nd its smooth as any other gear.
what's causing this
