rebuilt and upgraded
wes97tsi
Jun 5, 2012
Lakeland, Florida
I need to know if ill be okay when I start my car for the first time after two years. My 97 fwd eagle talon tsi just had the engine rebuilt and trans.. I'm hopeing that it will run good. I up graded my turbo to a tdo5 16g and with 650cc fuel injectors. I have a punishment racing intercooler with their given bov. I also have a 225walboro fuel pump. I have not upgraded my computer or any thing with fuel regulation. Question is will it be okay without a fuel pressure regulator and with a stock ecu.
No..Go back to the stock pump and injectors untill you get the proper upgrades.
Add dsmlink or safc, or 98-99 black flashable ecu..Add afpr..Get the proper things so problems don't arrise..
As stated don't use the injectors. The pump will possibly be fine (some stock regulators work with them, some don't). The injectors on the other hand will way over fuel the engine and likely cause you to spin a bearing from gas diluted oil.
