2G Rear wiper motor
just5_0
72
Feb 8, 2013
rogersville, Tennessee
So ni found out that the rear wiper motor doesnt work but the washer fluid sprayer does is the a relay for the rear wiper motor? I am not getting any juice to the motor i have tested all the fuses and they r good if ant 1 can help i would greatly appreciate it alot thank's.
It's probably rusted due to leakage. That was the problem with mine. Of course I could physically see it rusted put another one and now it work. Just a thought
There's no relay (well there's the rear intermittent wiper relay but it should still work with wiper switch on) but check if getting power through the rear wiper switch (light green-red in, blue-orange out to motor).
Oh my bad missed that it's not getting power, and you tested the line with a multi meter? Trace it hope you find it I hate dsm factory wiring job it's shotty.
T:thumb:hank's everyone i will try to trace it down to see ,it may be the switch idk but i will let everyone kn what it was if i figure it out. Thank's again esp for which wire is the hot helps alot.
Ok i check the switch and it is getting power in and power out to the wiper i went back to the motor and check it again green red wire and the most power i got was 0.07 not even 1 volt, is there a relay bf the motor and switch? If so where is it at? Thank's.:banghead:
Ok you're getting +12V on the small blue-orange (not larger blue-white) wire coming out of the switch (when turned on), but nothing on the small blue-orange going into the motor? Then you have an open connection between the two. There are 2 connectors between these that may be the problem or a wire is cut between them.
Ok thank's i will try to trace down the wiring and see.:thumb:
ok i found where it come's out of the hatch and it is disconnected, where does it go from there? I looked above the head rest and there are no wire's. Does it run under the back seat?
Ok i found where it pluggs in thank's alot i love this forum again thank's its working now ,you guy's rock..:hellyeah:
