rear wiper delete question
black97spyder
704
24
Oct 13, 2012
independence, Kansas
Hey guys I am wanting to do a rear wiper delete on my 97 tsi AWD. I was trying to just pop the wiper arm assembly off and couldnt seem to get it to budge, even with pb blaster.
My rear wiper motor doesnt work anyway, could I jus take a dremel tool or something similar and cut the arm off where it attaches to the motor? Shouldnt that let me get the wiper motor off so I can install my wiper delete grommet?
Thanks
There is a cover at the base of the wiper. Remove that and then remove the nut and wiggle to remove.
You can go to a honda dealership and get part number 82871-671-000 it will fit perfectly into the wiper arm hole and it only costs a couple bucks.
I already have taken the nut off and sprayed it with pb blaster and was wiggling and prying and the damn arm still wouldnt come off. I never thought to use heat but that should work :thumb:, jus have to keep clear of my paint.
It took me like an hour of wiggling it off because it was so rusted. WD-40. Then after I removed mine, I sawed off the wiper and sanded it down and resprayed it.
