rear window wiper on wrong
erlbassman
31
Feb 24, 2011
State College, Pennsylvania
I just bought my 95 gsx and i noticed the rear window wiper wouldnt work. After looking at it with my borther we noticed that instead of being vertical along the side of the window when not in use it is horizontal along the bottom of the window. when you turn it on goes down an gets jammed under the wing. so we are assuming that it is put on wrong. so my question is how do you take the arm off to put it on right?
Take the cap off the wiper arm and undo the nut. Wiggle the arm a little until it comes off but not too much because you don't want to mess up the gear teeth. Put it about 90* and see how it works. If it needs more adjusting then just move a tooth or 2.
thanks alot i did that and it works good now
so am i retarded I can not get mine off took bolt off wiggled and wiggled and still wont come off, i got the fronts off they turned out great, i covered my car and painted the back one well it ran a bit so i want to get it off so it looks as good as the fronts do
