Rear washer fluid not spraying nor my wiper moving
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
When I press the button to use the rear washer fluid, nothing happens and my wiper dosent move. My front washer nozzle and the wiper works perfectly fine. If I press the on button or intermediate, my rear wiper works. What could it be? Also, I don't hear a noise when I try and use the washer sprayer on the rear
I had this same problem and never could find an answer. So what I did was pulled up the wiring diagram and re wired the whole thing from the switch to the wiper to the washer motor to the fuse box.
Have you checked for power at the switch yet?
Not yet but wouldn't have to work because my rear wiper functions when I press the on button
Im sorry I totally missed you saying your rear wipe worked. Well then its not too bad. Go to the washer bottle and pull the plug for the rear motor and have someone hit the button while you check for power at the plug. If you have power then its going to be the rear washer motor.
I don't have a rear wiper since I have a Spyder, but my washer bottle is in the trunk like yours. I had an issue with mine where the hose got saturated with oil and swelled up the hose enough to let it slip off the sprayer motor and then it wouldn't deliver washer fluid to the windshield. This might be something to at least inspect for.
