rear strut mount kit install
Steveo823
Mar 20, 2011
St paul, Minnesota
i have a 96 eclipse gsx is there an easy way to replace the rear strut mounts because i recently hit a pothole
Need more info.
Otherwise, jack and remove rear tires, remove hatch covers over struts.
Remove struts. Use spring compressors to remove spring.
Replace broken parts.
Install using reverse of removal.
Yes it's assessable through the hatch the strut is fully extended on the top what more info is needed I'm kinda new to this stuff
And it's the rubber strut mounting kit I'm replacing.
