rear main seal causing low oil pressure?
southrneclipser
214
Jul 30, 2009
horn lake, Mississippi
i have reason to believe my rear main seal is leaking. its been doing it for about a week. Now my oil light is flickering on and off at random. my oil level isnt low yet so i asumed its causing me to have low oil pressure. i just wanted some more opinion on wether or not i have multiple problems or if its just the rear main.
Other than the oil level, the rear main has no effect on oil pressure. It's just to keep oil inside the engine instead of all over the clutch and ground.
Check the tension on your oil pressure sender wire where it slides onto the sender if your level is correct.
+1 if that doesn't solve the problem then replace the pressure switch $20.00 autozone.If that still doesn't work you may have a bad oil pump.
