1G Rear lsd upgrades?
As far as the lsd goes theres no difference in lock up between the 3 and 4 bolt. They both use the same viscous unit.Strength would be the only upgrade going from 3 to 4 bolt.I personally have a evo 8 diff with the clutches rearranged using the evo inner axle cups with the dsm 4bolt shafts and outter cups, and it is a WORLD of improvement for lock up! If you can get your hands on the evo setup for a good price jump on it!
Thanks! Seems like evo lsd is the way to go. I will start hunting for this setup.
